If you have one of our Custom 1-Click Installers, trying to Import Installs into Installatron the standard way, is most likely not going to work. However, there is a work around for this in which you can manually import installs into Installatron.
Just like when importing using Installatron directly, you can import an application manually from either within your hosting account that isn't controlled by Installatron or from another hosting account completely.
Importing within the same cPanel account
To start, some of the installers you may need to use this for include: Scalar, Mukurtu, and OHMS Viewer. However, this process can be used for any application which can be installed using Installatron but isn't importing the standard way. For this guide, we are going to be using a Scalar install.
- Log into cPanel and click on File Manager.
- Navigate to the directory containing the install and click Settings in the upper right corner.
- If Show Hidden Files (dotfiles) does not have a blue check mark, you'll want to click to add this and then click Save.
- Click Select All and then Compress.
- Select Zip Archive for the compression type.
- You will want to change the location and name in the box to the home directory and something like backup.zip (Note: it must end in .zip) and then click Compress File(s).
- This will put backup.zip in your Home directory. Once you have verified it is there, delete your install directory (don't worry, we'll recreate this in the next step).
- Now, go into cPanel and do a fresh install of the Application using Installatron. This will create the directory as well.
- Then go back into your File Manager (if you are still there, click Reload) and you will see your site doc root once again.
- Select your zip archive and click Extract.
- Type in the path to your doc root starting and ending with / as shown and click Extract Files.
- This will over-ride your current files with the files of your original site and connect it to what is in Installatron. You can now manage your site through Installatron!
Importing from a different cPanel account
If you are migrating one of these custom installer applications from one cPanel to another, you are going to want to follow the Moving Content to a New Location guide with one tweak. In the new account, you are going to want to do the fresh Install through Installatron prior to starting the moving process.
