cPanel provides two built-in options for provisioning SSL certificates. Both are free and work very well to install domain-validated certificates. At times, there may be a need to switch from Let's Encrypt to the more seamless approach of AutoSSL. In most cases, the Let's Encrypt SSL integration has been removed from our servers and cPanels. However, if your domain is on a legacy server that still has Let's Encrypt SSL and you're looking to switch to AutoSSL, this guide will cover the steps needed in the process.
Remove Let's Encrypt SSL
The first step is to log into your cPanel account. Next you'll want to find the Lets Encrypt™ SSL feature which is under the SECURITY section.
There will be a listing of all domains which have a Let's Encrypt certificate installed on them. Clicking Remove under the Actions column in the row of the domain you're looking to switch will uninstall the certificate.
A warning will appear asking if you are you sure you wish to permanently remove the certificate for the listed domain. Click the Remove Certificate button.
Once completed, a notification will let you know that the certificate has been removed.
Issue SSL cert via AutoSSL
Next, you'll need to issue the SSL cert via AutoSSL. We have instructions on how to do so depending on your specific cPanel version here: Installing Free SSL Certificates
If you have any other questions or need additional assistance, please reach out to support@reclaimhosting.com and we'll be happy to help.
