What Are My FTP/cPanel Credentials?
FTP cPanel Username & Password
When transferring large files using and FTP client, you’ll need to connect using your cPanel username/password. If you don’t know these credentials offhand, you’ll need to reference your account welcome email that was sent to you upon signup. It will look similar to the following:
Sample Reclaim Hosting account welcome email highlighting the section containing the cPanel and FTP username, temporary password, and server details.
Setting a new cPanel/FTP Password
If for whatever reason you do not have access to this email, you can always reset your cPanel/FTP password in the Client Portal.
Once you have accessed the Portal, click on the View Details button for the account whose password needs to be updated.
Reclaim Hosting Client Portal dashboard showing an active hosting product with the 'View Details' button highlighted.
From the Details area there'll be a menu on the left hand side where you can select Change Password.
Client Portal side navigation menu focusing on the 'Change Password' option under the actions management section.
From there, you'll be taken to the password reset page to create your new cPanel/FTP password.
The Change Password form in the Client Portal showing text entry fields for 'New Password' and 'Confirm New Password' with a 'Save Changes' button below.
Once you click Save Changes, your cPanel/FTP password will be updated. If this gives you any trouble, send a message to support@reclaimhosting.com.
0 out of 1 found this helpful
