Enable Error Logging in Omeka (Classic and Omeka S)
If you are working with Omeka and it’s not behaving properly, you can get a more detailed error message by turning on “development” mode. Below are the steps you can take to get that configured on your Omeka site for troubleshooting.
File Manager
Show Hidden Files
To turn on robust error messages, make sure you log in to your cPanel account and update your File Manager to show hidden files. You can do this by:
Click the settings icon at the top right of your screen:
Clicking the Settings button in the upper right-hand corner of the cPanel File Manager toolbar
Next click “show hidden files” and then click save:
Checking the checkbox for Show Hidden Files (dotfiles) in the File Manager Preferences dialog box and clicking Save
Omeka Classic
Omeka .htaccess Changes
You will then open the .htaccess file in the root of your Omeka installation. Find the following line, and uncomment it (that is, remove the # sign):
#SetEnv APPLICATION_ENV development
When you are done, it should read SetEnv APPLICATION_ENV development .
Editing the .htaccess file in the code editor to remove the hashtag symbol from the SetEnv APPLICATION_ENV development line
Once that’s done, reload your site and you should see an in-depth error on the page.
