Some plugins for Omeka and Omeka S, such as the CSV Import, Neatline and OHMS Import will require that you explicitly specify the background PHP path in order to work properly, as these plugins require PHP-CLI. To find out what version of PHP your site is running on, start by checking the MultiPHP Manager in your cPanel.
There, in the PHP Version column, you’ll see something along the lines of PHP 7.2 (ea-php72)
, which means you are using PHP 7.2. This is the PHP version you’ll need to specify as the background.php path in your Omeka config files. The paths for the PHP versions we offer are as follows:
- PHP 7.2 →
/usr/local/bin/ea-php72
- PHP 7.3 →
/usr/local/bin/ea-php73
- PHP 7.4 →
/usr/local/bin/ea-php74
Omeka Classic
For Omeka Classic, the setting is named background.php.path
and you’ll find it in: $OMEKA_ROOT/application/config/config.ini
Omeka S
For Omeka S, the setting is named phpcli_path
and you’ll find it in: $OMEKA_S_ROOT/config/local.config.php
