Migrating a WordPress Site Using Updraft Plus
WordPress and UpdraftPlus logos combined.The purpose of this guide is to show the steps needed in migrating a WordPress site using the UpdraftPlus plugin.
1. Installing UpdraftPlus
The first step is to log into the WP Admin area of the site you wish to migrate. This can either be done via cPanel / My Apps or through a domain link if provided by the customer. For example, https://mysite.com/wp-admin/.
Once logged in, we need to navigate to Plugins / Add New in the menus on the left-hand side.
Perform a search for updraft in the upper right search box.
UpdraftPlus WordPress Backup Plugin should be the first option available. Click Install Now.
When it shows the plugin has been installed, click Activate.
2. Generating a Backup
After activation, you will be taken to the Plugins screen. Locate UpdraftPlus - Backup/Restore and click Settings.
Click Backup Now.
The UpdraftPlus Backup and Restore main dashboard panel highlighting the large teal Backup Now button.
In the next window, make sure that Include your database in the backup and Include your files in the backup are selected. Click Backup Now.
The Take a new backup pop-up prompt in UpdraftPlus with checkboxes checked for including the database and files.
You will receive confirmation once the backup finishes. Please note that this could take a long time with large sites, and closing your browser window or tab will terminate the process.
The UpdraftPlus status progress bar window confirming that the backup run has finished successfully.
You will now be shown the different parts of the backup. This consists of the Database, Plugins, Themes, Uploads and Others.
Clicking on each backup part allows you to download them to your local computer.
3. Installing WordPress
We are now ready to upload the backups to the new server. The first step is to install WordPress if it hasn’t been installed already. This could be on our Shared Hosting service, ReclaimPress, or Reclaim Cloud, depending on your needs. You can check out these guides on how to install WordPress if you need help:
4. Restoring Backups with Updraft
Follow the directions above for installing Updraft Plus and once activated, click Settings.
We can now upload the backup files from the old server.
The next step is to perform the restoration. Click Restore.
To restore the full site, make sure each component is selected and then click Next.
On the second screen, Click Restore.
Once the restoration is finished, you will be presented with a Restore successful! message. You can then return to the UpdraftPlus configuration.
If you are changing the URL of the site during the migration, you'll want to work through our guide to changing the WordPress URL: Using the WP-CLI to Perform a Search and Replace
1 out of 1 found this helpful
