SQL Command for Mass Deletion of Moderated Comments in WordPress
Difficulty: Advanced
With comments marked as spam you can empty the folder (though if there are too many this might be less of load on the server), but there is no easy way to get rid of moderated comments that are spam. And if you get 10,000+, this could take hours to delete manually. Below is a quick trick using an SQL command in phpMyAdmin.
1. Make sure you know the proper database for your WordPress blog if you have several installed. You can find this in databases or the wp-config file in the blog directory (use File Manager for this). Once you know the proper database, click on phpMyAdmin in the cPanel dashboard.
2. Find the database of the site that has all the moderated spam.
The phpMyAdmin sidebar listing available website databases to choose from.
3. Look for the wp_comments table in the database, and click on that table.
A database table listing inside phpMyAdmin highlighting the wp_comments table selection.
4. You should now be in the wp_comments table. From there, click on the SQL tab.
DELETE FROM 'wp_comments' WHERE 'comment_approved' = 0
The phpMyAdmin SQL query input box with the custom comment deletion command entered.
You’ll get a dialog box confirming the command.
A JavaScript pop-up window asking to confirm the destructive SQL statement execution.
After that, you should have gotten rid of every commented that has not been approved.
