Reclaim Cloud makes it easy to auto-refill your account at specific intervals. Using Auto-refill is a great way to ensure your account never runs out of funds and your projects stop running.
You’ll first want to log into your account at https://app.my.reclaim.cloud/
Next, click Balance at the top of the Dashboard and select Configure auto-refill
A window will open showing the settings. If Auto-refill is disabled, you can enable it here as well or alternatively disable it if you no longer wish to have Auto-refill enabled.
The amount to pay can be adjusted using the blue slider under Sum Adjustment
This can range from $25 to $200. You’ll then want to select the option under Auto refill when for your preferred auto refill interval.
The options are…
- Weekly (every Monday)
- Monthly (1st of each month)
- Balance less than $ (A specified dollar amount)
Under Payment Options will be your existing payment method. If you would like to add a different payment option, click Submit a payment and enter the details.
