Client Area and cPanel Basics
If you’re new to managing your own websites, this might be the article for you. Signing up with Reclaim Hosting was easy enough, but now what? How do you begin to “Reclaim” your space?
Client Area
Understanding the basics of your Client Area is essential to utilizing your Reclaim Hosting services and to creating the perfect online space.
Your Client Area provides access to all of your account information & billing, as well as your cPanel.
When you log into your client area through the Reclaim Hosting website, you’ll be starting on the Home tab. This is where you can see your active domains, invoices, support tickets, and personal account information at a glance.
Screenshot of the Client Area home screen
Further on along the navigation bar, you’ll see a tab labeled Services. While you’ll get the very basics of your account on the Home page, clicking on My Services will give you a more detailed look into your Reclaim Hosting plan.
My Services will show a list of all your Reclaim Hosting plan(s). You can click on any of the services listed there to see your account details, change the password for your product plan, and manage your account actions.
We have additional documents you can read about upgrading/downgrading your account, as well as cancelling your account.
cPanel
Next to the Services tab, you’ll see a tab on the navigation bar labeled cPanel. Your cPanel is your control panel where you can access and manage the files and applications of your account.
For users with more than one hosting account, the menu item will convert to a dropdown menu to give you access to all of your cPanel areas from one screen. Read below to understand the basics of your cPanel dashboard.
By default, cPanel will put the Applications section first on your dashboard. Note that you can change the order in which your tools appear in cPanel using the drag & drop method.
Applications
Clicking on the Applications section will open Installatron; this is where you can install different applications (WordPress, Omeka, etc.) to your domain. My Apps will list your currently installed applications and All Applications will allow you to browse the directory of software available for installation in your account.
To understand more about web applications, read our community post: What exactly is a Web Application?
Databases
The Databases section allows you to create MySQL databases and users, and to modify and access to them. SQL stands for Structured Query Language. SQL is an international standard in querying and retrieving information from databases. There are several tools in the cPanel Database section:
  • phpMyAdmin: Manage a single database as well as a whole MySQL server.
  • MySQL Database & MySQL Database Wizard: Store and manage large amounts of information over the web; these are essential to running web-based applications like bulletin boards, content management systems, and online shopping carts. The Wizard guides you through setting up a MySQL database and user privileges.
  • Remote MySQL: Add a specific domain name so visitors can connect to your MySQL databases.
Domains
The Domains section of cPanel allows you to manage your addon domains, subdomains, aliases and redirected domains. Additionally, you can use the Simple Zone Editor (and in some cases, the Advanced Zone Editor) to map different parts of your domain to different services.
  • Site Publisher is an interface you can use to quickly create a website from a set of available templates created on cPanel. This is not a content management system we support here at Reclaim, but is available for you to use should you choose. We would instead recommend using one of the applications available in your My Apps section of your cPanel.
  • SiteJet Builder is a built-in website creation and design tool included for free with your cPanel. As with the Site Publisher tool, this is not something we can offer support for here at Reclaim, but is available to you with your cPanel.
  • Domains allows you to view and manage the domains connected to your hosting account. From here, you can add new domains, manage domain settings, configure redirects, and access options for addon domains, aliases, and subdomains
  • Register Apex Domain links to an interface you can use to purchase a new domain registration with Reclaim Hosting
  • Redirects map old domains to your existing domain.
  • Zone Editor is where you can manage the DNS records for your domains. From here, you can create and edit records such as A, CNAME, MX, and TXT records for your domains.
  • Dynamic DNS allows you to create and manage Dynamic DNS records for your domains. This is a unique use case, and for the most part, your DNS records will be managed in the aforementioned Zone Editor.
Email
The Email section in cPanel allows you to do many different tasks with email accounts. This includes creating and removing email accounts, forwarding email, etc. Note that for our Shared Hosting users, these email features are only available for Organizational Shared Hosting plans.
  • Email Accounts: Allows you to create email accounts, as well as pick your passwords for them. You can manage email accounts separately for each domain.
  • Forwarders: This allows you to send a copy of any incoming email from one address to another so that you only have one inbox to check. You can also use this section to forward all email accounts from one domain to another.
  • Email Routing: Allows you to reroute a domain’s incoming mail to a specific server; this is used to create a backup mail exchanger to take care of email in case a server fails.
  • Autoresponders: Set up an email account to send automated emails.
  • Default Address: This feature will “catch” emails that are sent to an invalid email address for your domain.
  • Mailing Lists: Creating a mailing list allows you to use a single address to send an email to multiple addresses.
  • Track Delivery: Exactly what it sounds like; track the delivery route of a specific email.
  • Global Email Filters: This interface allows you to create and manage your server filters for all of the email that your domains’ email accounts receive.
  • Email Filters: Create and manage email filters for individual email addresses to avoid spam and redirect mail.
  • Email Deliverability: Helps prevent spam so incoming and outgoing messages can be detected with verifiable information.
  • Address Importer: Allows you to create multiple email addresses or forwarders for your account. These can be imported via a CSV or XLS file from your computer.
  • Apache SpamAssassin: Allows you to manage email spam protection settings and control how suspected spam messages are identified and handled.
  • Encryption: Allows for messages to be encrypted with a “public key”, and decrypted with a “private key” that is retained by the intended recipient of the message.
  • BoxTrapper: Protects your inbox from spam by requiring all email senders not on your Whitelist to reply to a verification email before you can receive their mail.
  • Email Disk Usage: This utility allows you to recover disk space by deleting old messages from your mailbox.
Files
The Files section in cPanel includes the following tools - File Manager, Images, Directory Privacy, Disk Usage, Web Disk, FTP accounts, FTP Connections, Backup and Backup Wizard. To truly see the capabilities of these tools, the best advice we can offer is just to click & explore. We have a tutorial specifically for Backups.
  • File Manager allows you to manage all files connected to your account, including renaming, uploading, and deleting them. You can also get to your file manager using the Quick Links section at the top left of your cPanel.
  • Images lets you manage images that have been previously saved to your account.
  • Directory Privacy allows you to set a password to protect certain directories of your account.
  • Disk Usage helps you monitor your account’s available space.
  • Web Disk allows you to manage and access your website files directly through a file system interface on your computer.
  • FTP Accounts lets you create and manage FTP users who can access and transfer files for your hosting account. We have a tutorial on FTP.
  • FTP Connections is where you can view active FTP connections and monitor users currently accessing your account through FTP.
  • Backup  allows you to create and download backups of your website files, databases, and other account data.
  • Backup Wizard provides a guided way to create, download, and restore backups of your hosting account.
  • Git Version Control allows you to create and manage Git repositories for tracking changes and deploying website code.
  • JetBackup 5 provides access to advanced backup management tools, allowing you to create, restore, and manage backups of your hosting account. We have lots of documentation on using JetBackup and other backup methods available.
Metrics
cPanel offers a number of different monitoring and statistic tools to help you administer your hosting account. The Metrics section of cPanel includes Visitors, Errors, Bandwidth, Raw Access, Awstats, Analog Stats, Webalizer and Webalizer FTP.
  • Visitors: Use this to see your 1,000 most recent visitors for each of your domains.
  • Site Quality Monitoring: Ensures that your website is accessible and discoverable by scanning it for common issues and helping you diagnose and fix items.
  • Errors: This displays the last 300 errors on your site; helpful if looking for missing files or broken links.
  • Bandwidth: Bandwidth, also called data transfer rate, is usually expressed in bits per second (bps), and represents the amount of data transmitted through a connection over a period of time. Use this function to view the bandwidth usage for your site; see total usage, or by month. Includes web and mail usage.
  • Raw Access: This is another stats function that allows you to see who has visited your website without graphics. A downloadable zip file of your site’s activity is available.
  • Awstats: Allows you to see your website visitors with visual aides.
  • Analog Stats: Lightweight summary of your website visitors; simple summary.
  • Webalizer: Complex stats program; view stats by domains, hits, files, pages, etc.
  • Webalizer FTP: Uses the same concept as Webalizer, but uses FTP protocol.
  • Metrics Editor: Allows you to choose what stats programs you will use when viewing site statistics.
Security
cPanel has an entire security section devoted to protecting different parts of customer web sites from unauthorized access. The cPanel Security section includes SSH Access, IP Blocker, SSL/TLS, Hotlink Protection, Leech Protection and ModSecurity.
  • SSH Access: Allows secure file transfers and remote logins online. Watch our video on how to manage SSH Keys on Reclaim Hosting.
  • IP Blocker: This function allows you to block a range of IP addresses to prevent them from accessing your website. This is done by simply searching a qualified domain name.
  • SSL/TLS: The SSL/TLS Manager will allow you to generate SSL certificates, certificate signing requests, and private keys. These are all parts of using SSL to secure your website. Information is sent encrypted instead of in plain text.
  • Manage API Tokens: This feature lets you create and manage API tokens for cPanel API 2 and UAPI.
  • Hotlink Protection: Prevents other websites from directly linking to files on your website.
  • Leech Protection: Prevents your users from giving out or publicly posting their passwords to a restricted area of your site.
  • ModSecurity allows you to manage web application firewall settings that help protect your websites from malicious traffic and attacks. By default, ModSecurity is on for all your domains and we do not recommend turning it off for any reason.
  • SSL/TLS Status: You can use this interface to view the SSL status of your domains.
  • Two-Factor Authentication: Allows you to enable two-factor authentication (2FA), an improved security measure that requires two forms of identification: your password and a generated security code.
Software
The Software section of cPanel is located toward the bottom of your cPanel dashboard. The only functions you need to worry about in this category are Optimize Website and Installatron Applications Installer. More specific tools can be found within the Installatron Applications Installer.
  • Installatron Applications Installer: This function will take you to the Installatron interface where you can download new web applications, or manage your current ones. To learn more about web applications, read our community post: What exactly is a Web Application?
  • PHP PEAR Packages  allows you to view, install, and manage PHP extension packages used by your applications*
  • Perl Modules allows you to view, install, and manage Perl modules required by Perl-based applications*
  • RubyGems allows you to manage Ruby packages and libraries used by Ruby applications hosted on your account*
  • Optimize Website: This function allows you to optimize the performance of your website by tweaking the way Apache handles requests
  • MultiPHP Manager allows you to manage the PHP version assigned to each domain on your account
  • MultiPHP INI Editor allows you to customize PHP configuration settings for your websites by editing PHP options and limits
    *Note: Some packages and modules (such as PHP, Perl, and Ruby packages) may not be available for Shared Hosting accounts, as they can require server-level changes or installations that cannot be made on a shared server environment.
Advanced
Check out everything the Advanced section offers below.
  • Terminal: This interface provides command line access to your account on the server.
  • Cron Jobs: Allows you to automate certain commands or scripts on your site. For instance, you can schedule a command or script to run at a specific time every week to delete temporary files.
  • Track DNS: This allows you to find out information about any domain; trace the route from the server to your computer, for example. This can be helpful to make sure your DNS is set up properly.
  • Indexes: This manager customizes the way a directory can be seen (or not seen) online.
  • Error Pages: In two simple steps, you can select the domain you wish to work with, and then create/edit error pages for that site that viewers will see.
  • Apache Handlers: Controls how the Apache web server software manages certain file types and extensions for your site.
  • MIME Types: Tell browsers how to handle different file extensions.
  • Virus Scanner allows you to scan files in your hosting account for potential malware or security threats.
Preferences
The Preferences section is new with the new update of cPanel. This section can be found at the bottom of your dashboard. No need to worry about Contact Information. If you need to update your contact information, do so in your Client Area portal or by contacting Reclaim support.
  • Password & Security: Allows you to change your cPanel password. (However, there is no real reason to do this since you can enter you cPanel through your client area portal.)
  • Change Language: This tool allows you to change the language used in your cPanel Dashboard.
  • Contact Information: Set/Change your email address for cPanel/System notifications.
  • User Manager: Read our documentation on how to use User Manager.
  • Manage Team – The Manage Team page allows account owners to create additional users with limited access to certain cPanel features. This feature does not allow you to add users to share access to the same cPanel account; see our documentation on sharing account access for Shared Hosting accounts here: Add and Associate Users within the Client Area.
5 out of 5 found this helpful
