Troubleshooting FTP
File Transfer Protocol is a great tool for moving data in bulk, but it can be tricky if it's new to you. There are a ton of outliers that could result in that annoying “Login Failed” message, so knowing where to look can be helpful. We’ve got a great outline & explanation for all-things-FTP here, so we definitely recommend giving that a read & sending that to the user, but here are a few helpful questions to help troubleshoot FTP issues:
1. Is the student using a default FTP account or an FTP account that was created manually?
  • If the user is working with the default account that is created automatically when they sign up, they should be connecting via SFTP.
  • Any manual accounts that the user created or someone created for them needed to be connected to via FTP-SSL.
2. Is the student using the proper SFTP/FTP settings?
If you’re not troubleshooting in person, the easiest way to verify this is by requesting that the user send you a screenshot of their settings, not the error they receive when they can’t connect. The user’s settings should look similar to this:
  • Server: Domain name
  • Username: Same as cPanel credentials that were sent to the user in their account welcome email. For SFTP connections, they would just enter the username. For FTP-SSL connections the username would be entered as username@domain.com. For the account in the screenshot above, for example, the username would be labrumfi@labrumfield.com.
  • Password: Same as cPanel credentials that were sent to the user in their account welcome email.
  • Port: 22 (for SFTP), 21 (for FTP-SSL)
3. Is the student using the proper credentials?
Once confirming that a connection is possible, we always send the user their credentials (regardless if they have them or not) in a One-time Secret link, and then request that they copy/paste them directly.
If you ever need to check or reset their credentials, go to WHMCS > User Profile > Product/Services Tab. You can copy the username and password there, or set a new password if needed:
4. Is an SFTP/FTP connection possible?
Before even responding to the user, we always test an FTP connection on our end with the student’s credentials to make sure that this is indeed a user error and not a system error. Most of the time it’s a local error, but it’s still a good rule of thumb to eliminate all possible issues.
5. How many times has the student attempted to log in?
If the user has too many failed login attempts within a certain period of time, they may trigger a block on the server. In these cases, we also check their IP on the firewall to make sure that it’s unblocked and/or whitelists. We normally ask the user to send us their IP address by going here: http://ip4.me/
We have a guide for administrators on unblocking IP addresses here.
Reclaim Hosting also has a separate firewall on some servers called BitNinja. If you’ve passed through all of the above steps and the student still can’t connect, send a support request to Reclaim with the student’s IP and we’ll make sure it’s whitelisted there as well.
