EPP Codes (Transfer Authorization Codes)
An EPP code (sometimes also referred to as a transfer authorization code) is the code you need to begin a transfer of a domain from one registrar to another. It is provided by the domain registrar where the domain is currently registered. In order to transfer a domain registration to Reclaim Hosting a domain needs to be unlocked and the code is entered during the order process at Reclaim Hosting. For detailed guidelines on preparing a domain for transfer see Transfer Domains to Reclaim Hosting
While every domain registrar has a different control panel and guidelines on how to get the code here are a few tutorials for some of the more popular hosts...
GoDaddy
Bluehost
Namecheap
Hover
Dreamhost
Network Solutions
eNom
1&1
At Reclaim Hosting you can get your EPP code using the following steps...
1. Log in to your Client Area
2. Go to Domains > My Domains
3. For the domain you wish to get the code for, click Manage Domain
4. From this domain management interface you will find a tab called Management Tools and when clicked the dropdown will show the option to Get EPP Code
No problem, we're here to help! Talk to us about Professional Services.
