Subscriptions in ReclaimPress
We are so glad you've considered purchasing a subscription to ReclaimPress! As you're getting started, you can create separate subscriptions for each site you create on the network.
All costs on ReclaimPress are spent from your account balance, so if you have an account balance of $0 you will need to first add funds to your account. Check out our Getting Started with ReclaimPress guide if you need to learn how to set up your account, upgrade to a billing account, or add funds to your account!
Subscription Tiers
ReclaimPress has 4 levels of subscriptions, Silver, Gold, Platinum, and Diamond. Each tier represents the amount of resources you'll receive for each environment.
Silver
The sliver plan is the perfect place to start! The Silver subscription includes 1 GB of RAM and 20 GB of storage. It's currently priced at $5 per month.
Gold
Our most popular plan! The Gold subscription includes 2 GB of RAM and 20 GB of storage. It's priced at $10 per month.
Platinum
The Platinum subscription includes 4 GB of RAM and 20 GB of storage. Priced at $20 per month, it's a great plan if you need a little boost!
Diamond
Our top-tier plan is the Diamond plan at $40 a month. The Diamond subscription includes 8 GB of RAM and 20 GB of storage.
Purchasing a new Subscription and creating a Site
Once you're ready to begin, Sign up for a plan at https://reclaim.press. On the top right of the screen, you'll see a button to Create a New Project.
From there, you'll fill out the desired project name and subdomain you'd like to use. Click Continue.Screenshot 2024-03-22 at 15.31.23.png
Then select the Region you'd like the site to live in, then click Continue. Screenshot 2024-03-22 at 15.31.42.png
From there, you'll select your subscription plan. You can choose to keep Auto Pay or disable auto-pay as well. Click Continue.
Click Apply Subscription to add the subscription to your new site.
You'll be redirected to a Summary screen, click Create New Project, and you're good to go!
Adding another Site to an existing Subscription
What if you already have a subscription, say for a Silver plan, but you want to have two sites hosted on the silver plan? You can adjust the number of sites on a subscription at any time from the ReclaimPress dashboard. First log in at https://wp.my.reclaim.press then click on the account button at the top right, then select Your Account.
On the Your Account page, select Subscriptions from the sidebar.
Next, click on the Settings cog next to the subscription you want to edit, then select Edit Subscription.
In the Edit Subscription dialog, you can use the Quantity field  to change the amount of sites that your subscription allows. Note that the monthly cost of your subscription will be adjusted accordingly.
Now when you go to Create a New Project and are on the pricing tab, you will see you have a website available on your subscription, and you can click the Apply Subscription button to use it. Alternatively, if you wish to instead create a site using a different Subscription tier, you can use the Add a New Plan button instead.
