Installing SSL in ReclaimPress
This guide will cover how to install SSL on your WordPress site in ReclaimPress.
Once you've gotten your WordPress site set up in ReclaimPress, go into your site's dashboard and select the Settings icon in the upper right corner.
Then, select the SSL Installation tab, select your domain, and click Install.
That should be it!
If you have any trouble with this, reach out to us at support.reclaimhosting.com.
